- Mar 11, 2002
This isn’t my very first, but it is the first that actually works. I had tried some home made jobs, but I just don’t have the materials and equipment required.
Anyway, This is the Z4 kit from overclockershideout.com. I am not entirely happy with it. I have good idol temps with it (29-30 C), but want to do better before I overclock and put a load on it. Its an AMD 1800+ and a Soyo Dragon+ MB.
The Rad has to go. I was going to swap it out with one I ordered out of a auto parts catalog, but a friend is using it. I will try to find the catalog and order another. I also want to find some T fittings so I can split the water from the CPU and GPU. The kit didn’t come with any : (
Also, as you can see, I am having a problem bleeding air out of the water. I have been running this for a week now and still can’t get it all out. The reservoir/pump combo doesn’t seem to do the job well either.
