- Sep 27, 2003
- Thread Starter
- #21
Is it still crashing or was everything worked out?
I never heard back of any issues. I followed up with him sometime like maybe early Feb and he said it had been fine.
You don't have to set affinity to the program to select the other two cores?
Ahhh, I thought that part worked regardless... I have a key so I was unaware that it was DOA after 30 days.
What part of AIDA64 does not work after 30 days?
As far as I recall, at least the trial version, it just leaves gaps in memory testing but you can still use that after 30 days. I never tried the stress testing app with the trial version. That said, I have no idea as I have always had a key.What part of AIDA64 does not work after 30 days?
Can you download the portable and after 30 days just re-download portable to use again.
I have never tweaked AIDA for anything... what are you tweaking?
ahh... I only use it for stress testing and benchmarks.Window menu ordering lists (temps, what's listed that I want to see, remove what I don't care about from the lists), preferences, colors, and nearly anything that has a choice.
Yes I would not want to do that.If you didn't know already, on almost any trial software all you have to do is roll the date on your rig back and it works again.
Great. That doesn't tell me what a "portable" zip package is. Perhaps because its zipped its portable? No idea, LOL!
Why wouldn't an exe file be portable? I store it on the same medium.......
