- Jan 14, 2011
ok, so my movies are finally starting to saturate my 54Mbps wireless G atleast ive been getting 100% of it throughput and its lasted this long. now im going to venture into wireless N.
1. a decent wireless N access point / router that doesnt cost an arm and a leg. prefer access point as im going to be using pfsense soon and wont need any routing functions, the current router im using has dhcp disabled so its an AP pretymuch.
2. is there a way to force them to N only? id like the router to handle only N so i can leave the other on to handle the G devices so its not in bgn mode which from what ive seen is annoying as hell. lol
my htpc is the only one that uses/needs N.
i might end up running cat5e into the house like i have done with the whole mancave but im sure wireless N will get me what i want, just more throughput.
edit:
well i found this one i dont trust reviews on the egg for this kind of stuff as is usually idiots who dont know what an AP / router is.
http://www.newegg.com/Product/Product.aspx?Item=33-704-052 has removable antennas which could be a good thing.
edit i just looked on that your list matt and that one i randomly picked out of my cheap assedness was supported on the list and seems to have a decent ammount of memory. i think if i grabbed that up and a decent gigabit switch il be in streaming business 300Mbps of streaming powa that is
edit:
