Alright, hi fellow OCers and pc enthusiasts!
This is my first post in here, and I'm really looking forward for some suggestions / help regarding my setup.
My build is as followed:
Case:
-Corsair 750D
Mobo:
-Asus Sabertooth Z87
CPU:
-Intel i5 4670K 3,4Ghz
VGA SLI:
-EVGA GTX780 SC
-EVGA GTX780 Classified
PSU:
-Corsair 1200i
Network adapter:
-ASUS PCE-AC68
Storage:
-Corsair Force GS 240GB (SSD)
-Corsair Force LS 120GB (SSD)
-Toshiba 120GB (SSD)
Samsung 3TB (HDD)
I got 2x 24" monitors one of wich is AOC G2460P (144Hz)
I just put my rig under water last weekend and I've been trying to squeeze out every little drop of performance from it.
I currently have successfully overclocked my CPU to 4,5Ghz with 1300mV /1,3V.
I have also tried tweaking my GPU's to its fullest, altough theire both already slightly stock overclocked by EVGA.
I've been using tools such as CPU-Z and HWmonitor for CPU OC. For GPU I've been using MSI Afterburner, GPU-Z, HWmonitor, Furmark, Heaven and some games.
Noticed I've had a lot more trouble with DirectX after OC in both WoW and BF4.
Some questions to end my post:
A thing that confuses me in GPU-Z is that it says: "Bus Interface: PCI-E 3.0 x16 @ x8 3.0", which seems odd to me as both my GPU's are installed in a x16 lane PCI on my mobo and they both support x16 lanes. Why aren't they both running at x16? Some user on another forum said it was because it didn't need more than x8 or so. I've been trying to find a right solution through other peoples problems, but I couldn't quite find any forum or post that described it well. I have my network adapter connected to the 3rd PCI slot which is bottlenecked, but would that affect the GPU's?
Also, I installed my Classified in the 2nd PCI-Slot and the SC in the first. Will this affect my performance as the Classified is a bit more powerful? Do I have anything to gain?
And why is it that I can't see no changes on GPU-Z when I change my Volt slider in MSI Afterburner? It's like it won't accept change in voltage, I've seen people writing about Hard Volt Mod the 780's. But my GPU's only hit 1,175V at max.
Hope you at least enjoy my build, and replies are much appreciated!
Case:
-Corsair 750D
Mobo:
CPU:
VGA SLI:
-EVGA GTX780 SC
PSU:
-Corsair 1200i
Network adapter:
-ASUS PCE-AC68
Storage:
Samsung 3TB (HDD)
