Newbe question on Gigabyte 7vtxe+
Zadvocate
Im not an overclocker, and dont know much, bought a GA 7VTXE+ and AMD xp 2000, but noticed when I ran EasyTune that my CPU is only running at 1.25 ghz and when I check the help about in windows it says my CPU is only 1.25 ghz. I think there are jumpers or something in the Bios to tell the MB that its a xp 2000
How do I do that?
Thanks all
Z
There's a jumper on the motherboard, I believe it's at 100 when you buy the MoBo, changing it to the other position changes your FSB to 133, which would be right.
EasyTune has been very unstable with alot of boards, u should look into learning the manual way to overclock as that will give you more stablity
