newbee ?1600 agoia 212y ?
NEWBIE911
NE. from The IE
Why do i need to lower the multiplier from 10.5 .. Is there an advantage with a lower setting mmmmmmmm
can't i just increase the fsb and go from 10.5
FunkDaMonkMan
people lower the multi so they can obtain even higher fsb settings. If your pci/agp cards and ram can handle it.. you computer will run a lot faster with a higher fsb.
example...
10.5 x 133
8.5 x 164
are the same cpu speed, but the last one will give you better performance
Ozzman
yeah but also its a bit risky in the long run it sometimes damages stuff like ur harddrives and maybe a card or 2.. but other have no prob with it whats so ever. and if u dont then perfect but i found its not as stable with me.. but my ram is **** so im not suprised.
