I just build a new system and have a couple of questions before I start overclocking.
The system:
P4C800-E Deluxe
P4 3.0E
1 GB OCZ 3500EB
ATI 8600 Pro
Enermax 480w PS
Lian Li P60 case - 4 fans
Zalman CNPS7000A-Cu cpu cooler
Question 1 - I installed both Asus Probe and MBM5. According to these monitors my PS fan and case fan occasionally stop running. Of course, this is not the case as I can see the fans running. Also, on occasion, the CPU temp also jumps way high - its read as high as 90C. I immediately rebooted the system and checked the temp in the bios - temp read 58. I've check all the connections. Anyone know what's going on or anything to try?
Question 2 - CPU temps usually read in the low to mid 53-55 at idle and 63-66 when maxing the CPU. Are these temps ok? How far can I safely push the CPU temp when OCing?
thanks in advance
The system:
P4C800-E Deluxe
P4 3.0E
1 GB OCZ 3500EB
ATI 8600 Pro
Enermax 480w PS
thanks in advance
