Hi Guys,
I'm a newbie, let's be clear... i'm fumbling my way through this!
** I KNOW this is not the BEST way to do things, far from it in fact but it's just a bit of fun and curiosity.
So, I want to mine Dash.
I downloaded Dash Wallet, sync'd and generated a new "Receiving key".
I joined Suprnova.cc, added my Dash address to this, created an account and generated a worker (and also ticked "monitor" in my efforts to debug). Let's call the worker:
-u IHidUserName.1
-p IHidPassword
I then downloaded CudaMiner (I'm a GTX1080 user) and attempted to run it with the following command line (I don't believe it has a Config file?):
cudaminer -o stratum+tcp://dash80.suprnova.cc:443 -u IHidUserName.1 -p IHidPassword
This is the OUTPUT from it:
SuprNova give the following Config information, not all of it means something to me so, maybe the error is because I don't understand fully?
and.....
Settings for Stratum (recommended):
I've tried the default Stratum with port 9995, 80 and 443, all produce the same result.
I think, but could easily be wrong, that it is hashing correctly but unable to communicate back to SuprNova? Now, i'm 99.999% the user name and password are correct. Any other ideas?
Remember, this is my first attempt to it's likely to be something REALLY stupid on my part!
Thanks in advance!
-u IHidUserName.1
-p IHidPassword
*** CudaMiner for nVidia GPUs by Christian Buchner ***
This is version 2014-02-28 (beta)
based on pooler-cpuminer 2.3.2 (c) 2010 Jeff Garzik, 2012 pooler
Cuda additions Copyright 2013,2014 Christian Buchner
LTC donation address: LKS1WDKGED647msBQfLBHV3Ls8sveGncnm
BTC donation address: 16hJF5mceSojnTD3ZTUDqdRhDyPJzoRakM
YAC donation address: Y87sptDEcpLkLeAuex6qZioDbvy1qXZEj4
[2017-06-21 16:56:09] 1 miner threads started, using 'scrypt' algorithm.
[2017-06-21 16:56:09] Starting Stratum on stratum+tcp://dash80.suprnova.cc:443
[2017-06-21 16:56:10] GPU #0: GeForce GTX 1080 with compute capability 6.1
[2017-06-21 16:56:10] GPU #0: interactive: 1, tex-cache: 0 , single-alloc: 0
[2017-06-21 16:56:10] GPU #0: 32 hashes / 4.0 MB per warp.
[2017-06-21 16:56:10] GPU #0: Performing auto-tuning (Patience...)
[2017-06-21 16:56:10] GPU #0: maximum total warps (BxW): 1499
[2017-06-21 16:59:02] Stratum detected new block
[2017-06-21 16:59:25] GPU #0: 715148.66 hash/s with configuration T11x16
[2017-06-21 16:59:25] GPU #0: using launch configuration T11x16
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 432.76 khash/s
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 333.47 khash/s
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 346.58 khash/s
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 346.65 khash/s
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 336.24 khash/s
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 342.73 khash/s
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 331.65 khash/s
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 332.11 khash/s
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 338.83 khash/s
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 324.42 khash/s
[2017-06-21 16:59:25] accepted: 0/1 (0.00%), 324.42 khash/s (booooo)
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 342.64 khash/s
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 327.23 khash/s
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 319.33 khash/s
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 321.98 khash/s
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 322.97 khash/s
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 321.06 khash/s
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 311.69 khash/s
[2017-06-21 16:59:25] GPU #0: GeForce GTX 1080, 329.26 khash/s
[2017-06-21 16:59:25] accepted: 0/2 (0.00%), 329.26 khash/s (booooo)
[2017-06-21 16:59:25] accepted: 0/3 (0.00%), 329.26 khash/s (booooo)
[2017-06-21 16:59:25] accepted: 0/4 (0.00%), 329.26 khash/s (booooo)
[2017-06-21 16:59:25] accepted: 0/5 (0.00%), 329.26 khash/s (booooo)
[2017-06-21 16:59:25] accepted: 0/6 (0.00%), 329.26 khash/s (booooo)
[2017-06-21 16:59:36] accepted: 0/497 (0.00%), 287.16 khash/s (booooo)
[2017-06-21 16:59:36] accepted: 0/498 (0.00%), 297.85 khash/s (booooo)
[2017-06-21 16:59:36] accepted: 0/499 (0.00%), 297.85 khash/s (booooo)
[2017-06-21 16:59:36] stratum_recv_line failed
[2017-06-21 16:59:36] GPU #0: GeForce GTX 1080, 297.85 khash/s
[2017-06-21 16:59:36] Stratum connection interrupted
[2017-06-21 16:59:36] submit_upstream_work stratum_send_line failed
[2017-06-21 16:59:36] ...retry after 15 seconds
[2017-06-21 16:59:36] GPU #0: GeForce GTX 1080, 323.40 khash/s
This is a NGv2 Pool - you can use your Suprnova unified login here ! (All Suprnova Pools with this logo share the same login and worker information - no need to re-set everything !)
Suprnova's Dash Pool // Algo: X11 // LIVE !
Now also with Port 80 / 443 Mining!
You can also mine using Port 80 or 443 by pointing your miners to stratum+tcp://dash80.suprnova.cc:80 or stratum+tcp://dash80.suprnova.cc:443
and.....
STRATUM: stratum+tcp://dash.suprnova.cc
PORT: 9995
Username: Weblogin.Worker
Password: Worker Password
Thanks in advance!
