- Dec 9, 2002
- Northeast U.S.A.
I am new to Modding, so you can't make fun of my questions.
1) Do fan grills go on the inside or outside of cases and power supplies?
2) I want to dremel out the stamped fan grill of a Power Supply. Do I have to open it up to get any dremel dust out, or will the fan just blow it out?
3) I was thinking of bending the front intake grills on my power supply 90 degrees to increase air flow. The grills that are on the side of the power supply, not the bottom. Would it be better to just dremel them out? If so, is it okay to leave it open, because otherwise it ould need some type of home made rectangular grill.
4) Can a Dremel cut acrylic, lexan, etc...and router the edges of it?
Thanks.
Thanks.
