I've read most of the articles on overclockers.com and been hanging around in the forums for a while. I'm trying to push the o/c on my system a bit, and would appreciate any tips on what I should look at...
System:
Dual P3-733, Stock Intel HS/fan
MSI 694D MB with a blue orb stuck with thermal tape to the VIA northbridge (bridge was getting a bit hot for my liking).
512 Gen 133 ram (Hyundai i think.. nutthin special)
Leadtek GF4ti 4400
SB live!
P60 Aluminium case Stock cooling
3xHDD (one 80G, two 20G), DVD
I usually run my system clocked at 137FSB, and it's completely stable. It will also do most things at 143, but tends to drop out of most "heavy" games like Q3 and 3dmark.
A few quick questions then:
1. Are the problems I get at 143 more likely to be CPU cooling or RAM (or something else) ?
2. I seem to get problems when the CPUs go over ~43C. Is this normal ? Should the CPUs go to a higher temp than that ? (cant find any specs on the intel website).
3. Would additional case cooling help ? ( I live in a hot county where ambient temp is at least 35C in summer
cheers
Steve
System:
Leadtek GF4ti 4400
SB live!
cheers
Steve
