Newbie overclock question
Benchmark after RAM speed change..
[Sat Jan 23 20:50:41 2010]
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Compare your results to other computers at http://www.mersenne.org/report_benchmarks
Intel(R) Core(TM) i3 CPU 530 @ 2.93GHz
CPU speed: 4501.28 MHz, 2 hyperthreaded cores
CPU features: RDTSC, CMOV, Prefetch, MMX, SSE, SSE2, SSE4
L1 cache size: 32 KB
L2 cache size: 256 KB, L3 cache size: 4032 KB
L1 cache line size: 64 bytes
L2 cache line size: 64 bytes
TLBS: 64
Prime95 64-bit version 25.8, RdtscTiming=1
Best time for 768K FFT length: 10.970 ms.
Best time for 896K FFT length: 13.302 ms.
Best time for 1024K FFT length: 15.569 ms.
Best time for 1280K FFT length: 18.541 ms.
Best time for 1536K FFT length: 22.540 ms.
Best time for 1792K FFT length: 26.520 ms.
[Sat Jan 23 20:55:42 2010]
Best time for 2048K FFT length: 29.282 ms.
Best time for 2560K FFT length: 35.930 ms.
Best time for 3072K FFT length: 43.658 ms.
Best time for 3584K FFT length: 52.117 ms.
Best time for 4096K FFT length: 58.811 ms.
Best time for 5120K FFT length: 74.613 ms.
Best time for 6144K FFT length: 88.528 ms.
Best time for 7168K FFT length: 106.018 ms.
Best time for 8192K FFT length: 119.786 ms.
Timing FFTs using 2 threads on 1 physical CPUs.
Best time for 768K FFT length: 9.739 ms.
Best time for 896K FFT length: 11.713 ms.
Best time for 1024K FFT length: 13.256 ms.
Best time for 1280K FFT length: 15.824 ms.
Best time for 1536K FFT length: 18.999 ms.
Best time for 1792K FFT length: 22.633 ms.
Best time for 2048K FFT length: 25.048 ms.
Best time for 2560K FFT length: 32.917 ms.
Best time for 3072K FFT length: 40.478 ms.
Best time for 3584K FFT length: 49.068 ms.
Best time for 4096K FFT length: 54.351 ms.
Best time for 5120K FFT length: 69.384 ms.
Best time for 6144K FFT length: 82.440 ms.
Best time for 7168K FFT length: 99.010 ms.
Best time for 8192K FFT length: 109.757 ms.
Timing FFTs using 4 threads on 2 physical CPUs.
Best time for 768K FFT length: 5.376 ms.
Best time for 896K FFT length: 6.313 ms.
Best time for 1024K FFT length: 7.510 ms.
Best time for 1280K FFT length: 8.371 ms.
Best time for 1536K FFT length: 10.023 ms.
Best time for 1792K FFT length: 11.834 ms.
Best time for 2048K FFT length: 13.244 ms.
Best time for 2560K FFT length: 17.384 ms.
Best time for 3072K FFT length: 21.315 ms.
Best time for 3584K FFT length: 25.631 ms.
Best time for 4096K FFT length: 28.685 ms.
Best time for 5120K FFT length: 36.448 ms.
Best time for 6144K FFT length: 43.672 ms.
Best time for 7168K FFT length: 52.660 ms.
Best time for 8192K FFT length: 60.387 ms.
Best time for 58 bit trial factors: 1.796 ms.
Best time for 59 bit trial factors: 1.823 ms.
Best time for 60 bit trial factors: 1.824 ms.
Best time for 61 bit trial factors: 2.057 ms.
Best time for 62 bit trial factors: 2.139 ms.
Best time for 63 bit trial factors: 2.521 ms.
Best time for 64 bit trial factors: 3.102 ms.
Best time for 65 bit trial factors: 3.272 ms.
Best time for 66 bit trial factors: 3.418 ms.
Best time for 67 bit trial factors: 3.395 ms.
each time you take a screen-shot...make sure to have two instances of CPU-Z open, one with the CPU tab showing, and the other with the memory tab :)
That error looks like CPU speed/voltage. is the bclock still at 205?
VRAM??? The iGPU uses system memory :confused:
ok I am trying to get squard away.
A friend said its better to run lower multi's (8 to 10 x) and like 400 BCLK. What do you think?
I tried to do that but my RAM MHz was too high and I cannot find a divider anywhere. Do you have IM perhaps? I am meeting my friend on Myspace maybe you can help if you are not busy..:D
I'm at work...so no IM :(
world record bclock stands at about 293MHz right now...you friend was probably talking about older systems that use FSB...but that's an entirely different subject ;)
Did you try what this?
If you want to keep trying higher...then just run Prime95 for 5 minutes...if it doesn't have any errors, push the bclock up by 2MHz (with TurboV) and let it run for 5 more minutes...continue to do this until it does error (or lockup)...then report back :cool:
page file has nothing to do with OCing :confused:
Yeah I was just setting things up in Windows and I always remember to set page file to 1.5 RAM. I dunno why I brought that up..
I tried that and locked up then my friend was talking about different multi's and I got all screwed up.. Back to square one. I had to reset BIOS and start again.
Yeah...don't rush it man...what you need to do is read my OCing guide :p Too bad it's not posted yet :) drop the CPU multi down to x16 and work on bclocks first...see how high you can get the bclock, then go back and try to bring up the CPU ;)
Is there a RAM divider in BIOS? Friend wants me to run 8x and higher BCLK and need RAM divider. I told him it is different that CPUs with FSB. Not sure what else to tell him.
I was cooling with liquid nitrogen...so my settings were much different than yours. This is not my every-day system...I was only running it for HWBot points.
Wow you are FLYIN! Awesome job, and thank you for all of your help. I am at 210 x 19 slowly inching. My RAM is my downfall I think.. I will keep inching up the best I can. Thanks Matt, also for all of your help.
Maybe I will do some folding :)
