newbie succeeds, looking for ideas
DarkHawk
Salt Lake City, UT
I have an Athlon 700 and a K7M, I have had them running at 820 reliably for a good month now. CPu temps at idle are 48 C* though, and wondering if my pitiful 80mm side-intake fan and psu outlet fan are enough to cool the Aavid twin fan HS on it. Any ideas on how to speed it up on a very tight budget are welcome. I would also like to let everyone know that lots of money is not required for a good video card. I have a Viper V550, which came out long before the Viper II or the Viper V770, I then installed it as a Riva TNT by Nvidia and t runs like it was just that, with respectable framerates considering its a free card. I get 60 FPS on Max Payne on full quality and 640 x 480 x 16. Good enough for me til I get a better card. Not bad for a five year old card, huh?
DarkHawk
DarkHawk
Salt Lake City, UT
It seems a correction needs to be made...
the mb temp is accurate, but upon further investigation I found that MBM 5 is reading my CPU temp as -48 *C, I think that some might find this rather hard to believe considering I don't think its right. Any ideas on how to fix it?
Arkaine23
Captain Random Senior Evil
suggestions
You might try to make an air duct to channel the air from your side panel intake right to your cpu heatsink. I made one out of a rubber pvc adapter and it dropped my temps a couple of degrees. Only cost about $5.
Measure the temp in your case and in your room with a regular old thermometer and see how much hotter the case is... if its more than a few degrees warmer in there, you might want to think about adding a few more fans. Fans are cheap, but cutting holes in your case will require some tools.
NASsoccer
On a string I was held Senior
i live
are you sure that you chose the right sensor in settings? i know if i choose the wrong one i get a temp of 70c and well i knew that was wrong:)
