- Mar 18, 2002
- Media , PA
Help Guys, I just installed my first water cooled RIG in the following system:
ASUS A7M277
AMD 1.33 Thunderbird
512MB 2100 DDR Ram
Geforce 3 Visiontek Video Card
Sound Blaster Live Value
I am using a MAZE2 water block, with 3/8 fitting and a converted auto heater radiator, which is about 8”L, 6”W and 2” deep. I have a single 80-MM fan connected to the radiator. I lapped the water block and it looks like a mirror. I used Artic Silver 3 compound. My 145 GPH pump is sealed in a 4X4X4 reservoir. Water flow appears to be optimal. The system has four fans for airflow. NOW here is the problem, when I was using a heats sink and 6000RMP fan the idle temperature was 116F. With the water-cooling unit the temperature is now 118F. The water block appears to be snug on the CPU core
Here is the only thing I can think that may be affecting the temp. When I first removed the old fan and heat sink there was a large amount of generic white thermal compound, I was using the more is better theory at the time I installed it, and I used some cotton tipped swabs with carburetor cleaner to remove it. I got this idea from a listing in this forum. While cleaning the CPU the carp cleaner detached the four small sponge pads surrounding the CPU core. I used some very thin, almost water like, conformal compound, just a pin head drop to re-attach the pads back onto the CPU.
Does anyone have a clue why my temp is so high. Could it be the way I attached the pads back on. If I remove them and clean the area can I leave them off the CPU. Any help or suggestions anyone has would be most appreciated.
ASUS A7M277
512MB 2100 DDR Ram
