- Jan 9, 2006
The "warning: could not delete all work unit files", is bogus - you'll see that all the time, and it's wrong - because 5 seconds later, it does delete all the files it should be deleting.
Stanford considers this a "cosmetic issue", and has put fixing this, on the back burner.
The servers you tried are working - if you click on the url you'll see an "OK" reply.
So I'm guessing you haven't yet listed fah's client as an exception in your firewall's exception table, perhaps?
For Windows, it's: Start>>Control Panel>>Security Center>>Firewall>>Exception Tab>>Add a program. Whew!
Programs to add:
fah6.exe (I have renamed my fah executable "fah6.exe"). Use your fah executable's real name, of course).
mpiexec (I have 4 of these, you may need less)
smpd (I have 2 of these, you may need fewer)
Also, there is a checkbox you should mark: Says "Display a notification when Windows Firewall blocks a program." Be sure that is checked. You need to know if the firewall doesn't like some new client.
Let me know if that isn't the problem (the firewall), and I'll dig into your log files and etc., later this afternoon.
Programs to add:
