NF-7S & Barton 2500 Maximums
itshondo
CO
Just curious- How far have you been able to push your 2500 Barton?
NF7-S rev 2.0
I have my unlocked 2500 running at 210 X 11.0
timings 6-2-2-2.0
v-core 1.9
dram 2.7
chipset 1.7
Bios ver 20
I haven't been able to get much more
Try relaxing your RAM timing even though you have top quality RAM it still might help get a few mhz.
Mmmm I am pretty sure that his RAM is not the limiting factor in that system. The Mushkin stuff is more than capable of faster speeds than 210 FSB. My PC3200 Mushkin is at 230 FSB 2-2-2 timings.
The board itself might be the limitation though. I just replaced an NF7-S with a new one of the same (both rev. 2.0) and the old had problems getting over 217 FSB at any timings etc, wheras the new one is at 230. The older boards might benefit from a Vdd mod, yet my new one gets unstable at higger Vdd (even 1.7V).
I'd say look into the Vdd mod, and NB and SB cooling. Just my $0.02
Take off the nb fan, take off the tape, and apply epoxy.
Put a HS + fan on the sb.
Try lowering the multiplier to 10.5 or even 10 and then try using 2.8V for the ram. You should be able to get a few more MHz out of that baby. :)
my nb has a iceberg copper with artic silver 3 and the sb has a passive hs on it. I've tried lowering the fsb and pumpin' up vcore and vdim but it won't remain stable. Now I'm at 3200+ with timings 6-2-2-2 and some lower volts. Changing the timings hasn't worked either.
think I'll have to do a full work-up..
timings 6-2-2-2.0
v-core 1.9
dram 2.7
chipset 1.7
Bios ver 20
1 Lower muiltpier
2 lossen the timing's and up the voltage
3 vcore should be ok
4 some people have had better results with 1.6 and 1.5 vdd on the newier board's
5 Bios 10 for the best overclock (90%)
With your setup 2.5 3 3 11 should allow you to get the max fsb out of your mobo and cpu and after you get you max stable tighten the timing back to something like 2 2 2 11 if possible.
