NF7-S 1.2 help
dmon
Watertown,CT
I just put an NF7-S 1.2 in my system. I flashed to bios 17 booted up and can't drop the multi below 13 on my 2100. 9 to 15 worked an my A7N8X. Is it the 17 bios?
WinXP
SC
I am using a NF7-S v1.2 an a XP2100+ at 11x216 with the 16 bios, tried the 17 bios but it was not as good for me so went back to the 16. I have another v1.2 with the new 18 bios an it seems to be better than the 17 bios. Try clearing the cmos an reset your settings an see if you can use the lower multipliers. You should be able to use all of them.
D
dmon
Watertown,CT
Tried bios 16,17 and 18 still no luck. I don't know why it would work on my Asus and not my Abit. What do I have to do connect the 3rd L3?
