nf7-s bios problem
Hullahop
Denmark
Hi.
just got me a nf7-s and xp1700+. When i want to go into the bios 99% of the times it just gives me a blue line ind the bottom of my screen and hangs. i've tried to flash the bios, but it just said "please wait" for 15 minutes and then i restarted. the computer works fine other than that, but i would like to do a little oc'ing and tweak my machine. Is it just a faulty board??
hullahop
that is a problem
call tech support for Abit, RMA may be in order.
first thing, before you do that, flash her to the newest bios and see if it clears up, if it doesn't and all yer bios settings are right, then................
baldy:cool:
The "blue line" bios seems to happen when some of the settings changed in the bios, don't quite take properly. I saw it a couple times with mine before the bios crapped. What revision is your board? Are you using the proper bios files when you try to flash?
I would update the bios and see if that helps, the blue line is not something I would want to see my computer doing.:eek:
