Any DDR will probably work, just a question of how well. If you get good name brand stuff, you shouldn't have a problem. Two sticks of the same make, model, size, rating would be best because you'd expect them to both work about the same. Anything different and one of the two sticks will probably limit how much you can OC. If you didn't OC, then anything rated for the speed you're running should be fine.
