Nice GF4-Ti4200 3dmark
Bergfuerst
VIENNA/.at
Nice GF4-Ti4200 3dmark/more than 13100
Yesterday I owned again my XP1600+ and so I`d to test my new GF4-Ti-4200 64MB Agp 4x from Msi!
here are the Results:
13173 3dMarks
System:
Epox 8k3a+
Shuttle Spacewalker Memory DDR PC2100@ 170Mhz FSB(cooled by Cooling KIT-passiv)
Amd Athlon XP 1600+ Agkga@10,5*170->1793Mhz
Msi Gf4 TI4200 250/513@ 315/645(standard cooled)
Detonator:40.38
newest 4in1
Full image
whoa!
Ur saying u got that score with the card maxxed out but with factory cooling???
Whats ur case temp?
Just with the stock fan ?
Thats it?
I was thinking in getting a MSI, thats all i buy for everything they build , but now i got a even better reason.
The MSI GF4 TI4200 is a great TI4200 card. 2nd only to the albatron ti4200 turbo vid card.
My 3dmark2001 score is 13,132 also w/ stock cooling.
what 13,000+ ???
How do you do that? Can you tell me how to improve my 3DMARK 2001SE score? please...... My score is now 11,550 with the following configurations:
I have PixelView GF4 Ti4200 - 64MB @320/560, Abit BD7 mobo with Intel 845 chipset, Intel P4-NW 1.8A @ 2.61 GHz, 512MB DDR running at CL2.5 -7 -3 -3, 128MB AGP aperture size, Nvidia drivers 30.82, SBA and FF enable.
But....craps.... the 3Dmark score is still 11,550. I really don't know how to increase the score even higher. Are you overclocking your VGA is around 320/560 ?
U can start with a driver update to the detonator 40 drivers
u can find them off www.google.com
they improve performance by aprox 10% .
I notice a big improment on my system.
Can't say 10% but it sure helps
Re: what 13,000+ ???
Download riva tuner serach www.google.com
Lower your memory timings (lower=faster) 2-5-2-2 is the best
disable ff
I have PixelView GF4 Ti4200 - 64MB @320/560, 512MB DDR running at CL2.5 -7 -3 -3, 128MB AGP aperture size, Nvidia drivers 30.82, SBA and FF enable.
First of all, you need to o/c the memory of your vid card higher. Then use the most aggressive Memory settings possible. Also there are tweaks for opengl and directdraw settings also. don't remember which ones they are but do a search and you'll find lots of posts about them.
