DaddyB said:As I said over here it's probably a dead CPU, if it's a socket A board pop that xp1700 in it or try the CPU in question in that Abit board to see if it works.
i'm having the same problemJimmyG said:I assume that the computer doesn't boot up. If there are no beeps at all then you need to disconnect all drives and remove all cards except video. Remove all but one stick of RAM. Attempt to boot up. If it still doesn't boot, and there are no beeps, then remove the last RAM stick. Try to boot up. You should get some beeps. If not, then you may have either a bad CPU chip, a bad mobo, or a bad PSU. Try them in another computer if possible to determine the bad part.
