No Desktop Icons in XP
minoukat
Ottawa, Ontario
use the new Start Menu ? or use TweakUI
EDIT : or go to Display Properties, click on Desktop, click on Customize, and play with what you get there
M
Matthew1001
Birmingham, Alabama
Yeah, that is where I looked before.
Oh well, I just removed all the icons in the Unused Icons Folder. I left a few (recycling bin, ie, aol, and wmp).
redduc900
Inactive Moderator
Portland, OR
You can use the Group Policy Editor to...
  • Hide and disable all items on the desktop
  • Remove the My Documents icon from the desktop
  • Remove the My Computer icon from the desktop
  • Remove the Recycle Bin icon from the desktop
...and a number of other items (as long as you're logged on as Administrator)
Start | Run | Type gpedit.msc and press OK | Navigate to the following branch...User Configuration | Administrative Templates | Desktop ;)
