- Oct 4, 2002
- Corinth, MS
Posted by Epox Tech from this thread. http://www.aoaforums.com/forum/showthread.php?threadid=11033&perpage=20&pagenumber=1
"Hiya there. The AGP lock is to assist poor graphics cards with higher bus speeds / experimental overclocking measure. PCI is still an issue with which to contend. PCI/AGP lock only features on our P4 product for reasons that will leave it only on such platofrms - as much as one wishes or dreams - physical limitations do exist."
Followed by this question.
"Ok well if there is no PCI lock then what is the highest PCI divisor that will be available? is it still 1/5 or does this new board have 1/6 divisor?"
And this response.
"I prayed you wouldn't ask that one !! Pls don't ask me that one. Gives me a feeling worse than tooth ache. The board will stably do 200MHz sync if set correctly, that's all that matters."
So I guess it doesn't have a PCI lock. I'm not sure if this is the case for all of boards but I would assume it is since it's likely a chipset limitation rather than a manufacturer's problem. Anyone with a Asus, Chaintech, or Leadtek nforce2 motherboard wanna shed some light on this issue? Thanks.
And this response.
