No Post! plz help!
DzNuts
my IBM hard drive is on its way, so I put together my rig without a HD, fired it into bios, worked great... so I go to manual setting of my clock and forgot and put it at 133 , when I only have a 100 chip, the 1.4(200). I hit f10 to save and reboot, but the thing wouldnt reboot, which I figured would happen, but after reseting and turning off and on it still wouldnt set itself to 100 and post, so I manualy set the jumpers to 100 , no luck.... so now I'v removed the battery from the mobo and unplug'd it, hoping after a few hours the cmos would reset... have I missed something? or am I doing the proper steps? would could that have done setting it to 133 like that?
thanks
Ryan
14x100= 1400
14x133= 1860
Well if it actually tried to boot I suppose it could overheat pretty fast.
Kind of doubt it thou sounds to me like you are taking the correct steps.
Goodluck.
