Noctua industrial ppc vs corsair af 140
Mikesamo
san jose CA
hi i just installed 2 noctua a14s as intake fans and hooked them to my fan controller . if i try to use the lowest fan speed setting the fan will attempt to turn off completely than jump up to 100 %. so I used bios and ran at 30 % . superior airflow vs the corsairs maxed out ! . photos are below
Mikesamo
Mikesamo
san jose CA
:D
JrClocker
AKA: JrMiyagi
The Noctuas have a higher static pressure...so that makes sense.
In the Corsair case in my "Mini Folder" (a "high airflow" case...aka low resistance) the AF fans were the same airflow, but quieter for me.
ATMINSIDE
Makes sense... One is a top tier fan and one isn't.
Did you get the PWM model?
ATMINSIDE
Ah, you got the 3000RPM model, I have the 2000RPM myself.
What fan controller are you using? You should be able to control down to ~10% on a PWM signal.
Mikesamo
Mikesamo
san jose CA
my lcd fan controller couldn't run this at anywhere near 10 % . if I try what happens is the fan will shut down completely than torque to 100 % . 40 is the lowest i could do on the sentry . I hooked to the motherboard instead and used speedfan . works wonders . I can go as low as 5 %
ATMINSIDE
There you go, get a powered PWM fan splitter like the one made by Swiftech and control them all off your system temperature via a motherboard header!
Mikesamo
Mikesamo
san jose CA
I have 3 open channels but they're all tied down to the cpu temperature. I created a gpu temperature control on the noctaus . they don't spin unless the gpu heats up . " gaming mode "
ehume
You may have gotten too high rpm fans. The NF-A14 PWM works well. I myself am using the NF-A14 ULN fans as front intake. They are running 750 RPM ATM. They come with speed reduction cables that get them down to about 600 rpm.
