- Feb 4, 2009
- cypress, tx
I have a pair of Noctua NH-U9DO A3's I am going to upgrade my server to LGA 2011, but it uses narrow ILM as opposed to the standard square one. Does anyone know if the narrow ILM bracket will work with those coolers and were to purchase one? The NM-I2011 looks like it only works with 2011-0 and 2011-V3 square mounts so it is useless to me and that is the only 2011 product I can find...
From what I can tell the narrow ILM mount should work without issue, but after emailing Noctua they said it is not mechanically compatible. That being said they also say it doesn't work with the NH-D14 and it does minus ram clearance issues with the coolers width.
Can anyone confirm either way? I would rather use the U9DO's instead of downgrading to the NH-U9DX i4...
