Noise when higher CPU usage?
JustDepends
Canada
Is it normal that when i play a game or run prime95 test it sounds like something is getting louder. Its like a buzzing that you can't really tell that it's there until it stops. I can kind of hear it now but its not as loud. So is it normal.. Do i have a problem?
Xtreme Barton
my first question would be who made the brownies (jk'ing)
and ive never experienced abnormal noises i personally would think its not normal ... not to say that anything is gonna die for sure but who knows .. what are your temps ? and what voltages you running ?
JustDepends
JustDepends
Canada
Uh temps are are around 35-45 on idle and 63-72 running prime95. And my voltage is 1.360. And as you can see down below, i have an i5 750 at 3.8ghz.
Xtreme Barton
have you trie backing off your clocks to see if it goes away ? its def not coming from your psu right ?
JustDepends
JustDepends
Canada
These where my 2 main thoughts. Some psu's make a buzz after a % of power is being used and sometimes its just the fans going faster to cool the system.
I only notice the sound becoming louder when the CPU usage gets higher. Doesn't the voltage remain constant even when the CPU level of use increases? And i'm almost certain there is no sensor to increase the fan speed.
Hopefully its the PSU because that's cheaper to get a new one and bonus i have a lifetime warranty. If it were to break.
Xtreme Barton
take a toilet paper roll and put it o your ear ( a clean one) and try to see if you can pinpoint the noise a little better .. and be sure to post picks of you doing that :D
JustDepends
JustDepends
Canada
Could it be my hardrive?... now that i have listened to it more it sounds a little bit like a disk spinning.
