I just finished some benchmarking comparing the hsf setup in this thread, to the new Millenium Glaciator. You've seen the pics of the Alpha above, I put a pic of the Glaciator below...
Alpha PEP66T vs Millenium Glaciator
Tests were both run today, using my Celeron 600 @ 1008 MHz, 2.05v. Ambiant temperature at or about 78f/25c Temps measured with Asus Probe.
Test 1; PEP66T, with Delta 60x60x25 fan, 38cfm, silicone mounted to sink, "blowing" on sink
IDLE Temp 20 - 21c (idled for 5 minutes to stabilize)
LOAD Temp 28 - 33c (running Prime95 Torture Test, 30 minutes)
MB Temp 29c throughout test
FAN rpm 6490 idle, 7031 load
Test 2: Millenium Glaciator, as shipped, unmodified
IDLE Temp 21 - 23c (idled 5 min)
LOAD Temp 33 - 34c (Prime95 Torture Test, 30 min)
MB Temp 28c idle, 29c load
FAN rpm 4891 idle, 5273 load
I'm sure most of us are familiar with the "ear splitting whine" of the Delta 38cfm fan. It's loud. VERY loud. Even with the case sides on, I can hear mine running outside my computer room, and down the hall. ??? That's how the Alpha above sounds.
The Glaciator, on the other hand, cannot be heard with the case side on, over a pair of 92mm case fans (that aren't very loud, either!). This is what impressed me most about this hsf. It's lack of noise. This whole unit is a well designed piece. That's a fairly moderate to heavy overclock goin' on there, and it kept the temps under 35c, and drops down to idle temps fairly quickly after load is removed.
The Alpha was a couple of degrees celcius cooler, but the Glaciator was significantly more quiet. If you need the cooling capabilities of the Alpha/Delta, but don't want the noise, this new hsf might be just what you're looking for.
Mr B
