- Jan 24, 2002
- Toronto, Canada
Well, I got a pair of nice Polk Audio 40 WATT bookshelf speakers. Obviously non amplified. I really have no other use for them, but for the PC.
My current audio setup is simply ancient, I have a 2.1 speaker system, made by some noname company that I bought for 15 bucks about 3 years ago. My soundcard is Nforce2 audio though, so that aint too bad.
Anyways, how would you go about hooking up the non amplified speakers to my PC?
So far, all I can think of is, taking my current 2.1 speakers, cutting the sattilites off (yes its that cheap, satt's cant be jacked out), and connecting the Polk Audio speakers to the powered SUB. However, the problem lies in the SUB itself, since it sounds simply disgusting. Also, I cannot open it up, and just cut the wires to the SUB inside, since its a 1 piece solid POS unit.
Other way would be using an amp such as a bookshelf system with AUX in, but I have no space in my PC room for that, and I am a very very cheap man.
Anyways, any ideas guys?
Thanks in advance ;p
