None pelxi case
homemadevolcom
pittsburgh, Pa
I Just bought a case and came home to found out my mobo doesnt fit. I May still buy a case but I dont know what kind, where, and what are good for modding. I want a side window mod and some fans. Any help is useful.
Avatar28
No, I showered
Nashville, TN
You'll be doing good to find a decent case for $30. A Window mod alone usually adds $30-50 to the price of the case, depending on where you go and if you want it installed or not.
Sonny
Senior TIFOSI
VARIANTE ASCARI
LOOK HERE for some good deals.
$39USD + S&H for this rather large example.
$20USD + S&H for the baby brother.
eh?
Elkhart, Indiana
there are alot of cases under $30... its the shipping and handling that will kill you, also i don't know where you buying your window mods from but i seen them all over for 19.95... try here thats cases with a 400 watt psu and the cheapest is 17....the super case is what sonny showed you that is a good case and they are pretty cheap.... Welcoms to the forums
Avatar28
No, I showered
Nashville, TN
I was including the shipping in the price of the case, so I stand by what I said there. The Window mod price should have been $20-50, which would be about right. If you buy the case and want them to install it for you, it usually is going to run you more towards the high end of that.
