- Mar 5, 2002
- Middle-Earth
I have this for memory I am new to using DDR Memory
I assume I want these BIOS settings
DRAM Timing Set = Normal
CAS Latency Time = 3
Active to Prcharge Delay = 7
DRAM RAS# to CAS# Delay = 3
DRAM RAS# Precharge = 3
Refresh Mode Select = ?
What does the "Spread Spectrum Modulate" do?
With my memory, should I use the 1:1 or 4:3 FSB setting?
At what kind of FSB did you have to change the Vcore, and/or Vagp, and/or DDR V adjust?
