- Jul 22, 2002
- USMC.. OoRah!!
I got all my measurements done and all. The case it going to be made out of Plexi glass (AKA Acrylic) I knows its not the BEST stuff around, but I'm pretty sure it'll suit my needs. Its going to be 5.50" wide and about 18" tall. I plan on installing 2 120mm 85cfm fans in the front ( giving me an airflow of 240 cfm in) and 3 80mm fans in the back ( giving me 240cfm out ) and one 80mm in the top of the case to help vent hot air that rises. I got an Athlon XP 1600+ now @ only 1.6. with the ATX mobo, 350w PSU, video card, sound, etc. etc. How would you reccomend putting together the sheets of acrylic? would a siliocne sealeant or adhesive do ok? Also, what would u reccomend to cut the acrylic with? Or would u reccomend assembling the case with fine threaded screws? I plan on painting the mobo with a non-conductive glow in the dark paint. So my vision, I ope, is for theis case to be pretty cool looking. Youcan check out my sig to see my specific system stats. Thanks a lot
