noob needs help... first time overclocker!
AMD4Life
Canada eh!
Ok this is my first time OCing well not yet need some answer before i start. First off i have been searching and reading and found some answers but i have specific questions.
1. When using prime 95 do i use primenet or the torture test? and how long do i test it in prime 95 and memtest?
2. Do i turn my multiplier right down...I can go to .5... and start turning up the FSB till i doesn't boot? or till it gets errors in prime 95?
I read in the forums somewhere that i should turn the multiplier right down as low as it can go and the raise the FSB leaving it at stock voltage. when i get to the highest FSB then i start upping the multiplier until it doesn't run stable then i would up the voltage. Right?
Oh yeah one other thing what bios should i use the hacked bios or the one from abit? I also heard that some of the new mobo's won't run wuth the hacked bios'. i got my board a week or two ago.
Any help would be helpful
thanks
c627627
c(n*199780) Senior Member
To test the stability of overclocked CPU, download the latest bug fixed version of Prime95:
http://www.mersenne.org/freesoft.htm
Double click on PRIME95.EXE to start the program.
Just Stress Testing (if prompted) > OK >
Options > Torture Test > Blend (if prompted) > OK
The program should not give any errors.
It may be necessary to run the program 12-24 hours to make sure an overclocked system is stable (no program errors displayed).
If you get errors only after several hours, this is a result of slight instability because the system is running with little or no margin. It's stable enough to boot and to be moderately stressed, but as soon as the system is under enough load to go over that critical point, it will freeze. To be 100% stable, Prime95 should run 12-24 hours without any errors.
The point of testing is to see if you get errors or not thus testing the stability. The meaning of errors themselves is not as important.
Running Prime95 Torture Test for 5 to 30 minutes is enough to get a feeling about general stability. If it seems to be stable, increase the FSB (with 0.025V Vcore increase if needed), or increase the multiplier by 0.5.
Reboot and run Prime95 Torture Test for 5 to 30 minutes and repeat this until the Program displays errors.
It's then time to back down and repeat the Torture Test until there are no errors for at least 12 hours.
It's OK to use the computer while Prime95 Torture Test is running in the background.
After finding your stable point you may want to then retest by going to the Advanced section, setting the password to 9876 and then setting Priority to 10. (You won't be able to use your computer while Priority 10 Prime95 Torture Test is running, but it'll confirm your system stability.)
Use 3DMark to test video card stability.
