s33kgr, that's one of the best examples of a computer in need of some serious cable management I have seen in a while. You definitely need to give some attention to that. Is that the way the builder left it or is that the result of your cooler remounting effort? But Mr. Scott is correct, it's not the real problem. If it had been, then removing the side panel would have made more difference in temps.
The real problem is turning out to be an inferior CPU cooler. Despite it's size, it's not particularly efficient and the reviews of the product don't give it particularly good ratings in that regard. Whose choice was that to use that cooler? Yours or the dude who built it? For the same money, at least in the USA a better one could have been installed. One major problem with that cooler is that the fan is not strong. Quiet but not strong. A twin tower cooler like that really benefits from have two fans, one for each tower. Are you open to changing that component? Not trying to be mosey but would the cost of doing so be an issue with you at this point in time? With your high ambient temps you need the best cooling you can afford.
And the top fans and getting a thinner one question you asked earlier? Just move the top two fans to the top side of case rather than under the top case panel.
Looking at the big picture, you can probably get to 3.8 ghz with your current equipment. If that's good enough then don't spend anymore money and let's get to work at achieving the best overclock with what you have.
Better this way.
Why? The 1090T has an unlocked multi.
I don't disagree but, the difference is so minor. If you're benching, sure, but this is a daily 24/7 rig. IMO, not worth the effort. Close is good in this case. Keep it simple.Because we know from experience that you can get the same overclock with a little less vcore if you involve the FSB in the overclock on this generation of AMD CPUs. And with his cooling issues we know that every little bit counts.
Okay. First thing is to lower your memory frequency to the 1333 MHz divider so we can make some headroom for overclocking the FSB. The memory speed will climb upward with increases in the FSB. So we must lower it to start with in order to account for this.
3. Lower the HT Link and CPU/NB multipliers temporarily to 8x.
4. Manually set the RAM timings to what they are when the RAM is running at 1600 mhz. Don't leave the Timings on Auto. They need to be a little loose to start with.
Yes, you have circled the correct controls in your pics for the CPU part. Leave HT Link Width alone. HT Link Frequency is the one you want to adjust. Take things off of "Auto" and you will see numerical frequency values or multipliers that can be changed. Keep in mind that with the CPU components (CPU frequency, HT Link frequency and CPU/NB frequency) the frequency will be the product of the FSB and the multiplier. So, for instance, with the FSB at the stock 200 and the HT Link multiplier at the stock 10x your HT Link frequency will be 2000 mhz (200x10). If you lower the multiplier to 8x the frequency will be 1800 mhz. On the other hand, if you increase the FSB to say, 225 mhz and leave the HT Link multiplier at the stock 200 then the HT Link Frequency will be 2250 mhz. All of those CPU components have limits as to how high they can be overclocked. Any of them can cause instability if pushed too far so at certain points either their frequency has to be reduced or their voltage has to be increased or both in order to maintain stability. With the Thuban core CPUs like you have keeping the HT Link and the CPU/NB frequency in sync with each other generally gives the highest and most stable overclock. Generally, I say. Some exceptions for individual chips. Usually you can get them both to about 2500 mhz without a problem if you add a little voltage to the CPU/NB. No voltage should be added to the HT.
Memory frequency also rises as you increase the FSB frequency but it's a little more complicated to figure what it will be if you raise the FSB by a given amount. The reason is that the memory frequency uses a divider or a ratio like 7/8, 4/5 or 9/10. You can check that ratio in the Memory tab of CPU. It's just easier to check the value in CPU-z of the memory frequency instead of trying to figure out what it will be.
Concerning memory timings, for right now just leave them on Auto. We'll deal with that later as necessary.
So go back now and implement the instructions I gave in post #50 except leave out step #4 for now. Then post back with pics of CPU-z tabs: CPU, Memory and SPD.
