- Jan 4, 2004
Hi, I am new to the board and to cooling and all that fun stuff.
I just built me a new computer system. here is the list...
Abit IC7-G MAX II motherboard
P4 2.8 800FSB
1GB Kingston HyperX PC-3200 DDR
Asus Nvidia fx5900 Ultra 256mb
WD 80gb 7200rpm HD
Plextor CD-RW
DVD drive
Vantec Fan Controller
My main question is what is the best way to setup the fans. I read a few post about blowhole and such but I am not sure what is best way to get the best temp. Right now the way I have them is
2 Rear Vantec Tornado 80mm as intake,
1 side Tornado 80mm as intake and
2 front 80mm as intake. (The two front are not tornados they came with the case not sure what kind they are.)
1 80mm tornado at top as blowhole like some have suggested in posts i have read.
At Idle with this setup and the tornado fans on low through the fan controller my temps are SYS 28c, CPU 37c, PWM 30.5c.
I never let them run at highspeed for long enough to see how it effects them but I figured if these are good temps then I do not need to run them at highspeed unless I am making the computer do alot of work. Are these temps good for idle or should they be lower? Any input you have is greatly appreciated and sorry for the long post.
P4 2.8 800FSB
WD 80gb 7200rpm HD
Plextor CD-RW
DVD drive
