Hi pls help me!
yesterday I bought
7600x
Asus b650 tuf plus wifi
Trident Z5 RGB 6400 CL32
deepcool le520
I'm a beginner so I did what friends advised me....
first thing I did was updating bios TUF-GAMING-B650-PLUS-WIFI-ASUS-3024.zip and then I used DOCP II and 6000 ( I heard I should use 6000 for ryzen 7600x and DOCP II is better than DOCP I - I couldn't find a good expo amd ram so I bought a good intel xmp ram that I could find!)
https://i.ibb.co/ggXVn4w/image.png
and then I started to use my PC and everything was great but my friend told me it seems the voltages are not correct!(+cpu fans were loud and I lowered them and restarting PC was taking so long)
so I did these things:
https://i.ibb.co/SsJ6q8h/image.png
Then I saw this on the internet
""The VDDIO is high, typically 1.25 is recommended if you are OCing""
so I lowered CPU VDDIO \MC voltage to 1.25
https://i.ibb.co/0hZL7gS/image.png
and results are now like this:
https://ibb.co/Hg759PR
https://ibb.co/w0GW8TL
https://ibb.co/D8dhdG2
https://ibb.co/n6YmXDX
now my friend tells me that my Vcore is high and I should lower CPU core voltage in bios! is he right? is my vcore high? ( is there any difference between vcore in hwinfo and CPU core voltage in bios? sorry for stupid questions!!!)
is everything 100% ok with my PC and my voltages(vcore - soc voltage - CPU VDDIO \MC voltage and etc)?????if not what changes should I do?
pls tell me the normal voltages for each one of these in hwinfo for 7600x
lowering some voltages is safe right? i didn't not increase anything as you saw here:
I just lowered some voltages that seemed they are higher than safe!
can I use my current settings for years without any issues?
Pls guys answer to all of my questions, thanks
yesterday I bought
7600x
deepcool le520
