- Jun 16, 2001
I am sure you have at one point in time seen the crap heatsinks that some people put on your system when you buy them. Those nasty little black odd sized heatsinks with a fan that can't move enough air to even cool your hand if its sitting in it. Most of these fans are in the 40mm to 50mm range.
Well this is what I did. I took the plastic off of the greenie on the northbridge and put it back on with thermal paste and 3 dots of super glue on drop per corner all but one. Then after sometime of not being happy with my system and also upgrading my CPU to a 633mhz Celeron 2 cC0 stepping. I found the joys of 100mhz FSB. Needless to say my system temps went up. So I racked my brain trying to find a way to take the heatsink from my GPU and that crappy 40mm fan and put them on my Northbridge. It was a no go transistors were in the way so this is what I did. I super glued the fan to the greenie which in turn has dropped my temps down a good 4ºF.
