NorthBridge WB?
Istari1
Raleigh NC
Ok, so basically is this even a reasonable idea? I know the northbridges of a KT266A can be a little warm, but I've never seen evidence that great cooling on a NB actually effects anything. Any articles out there that show a difference? ALso I am going with a pretty high flow system (500 GPH pump and heater core), will a NB cooler kill my systems flow rates? All the ones I've seen look very small and seems that those small channels would cause alot of back pressure (even with 1/2" fittings).
Josh
Diggrr
Underwater Senior Member
Here's a decent article describing what whatercooling can and can't do for your northbridge: http://www.overclockers.com/articles423/
Even if your not overclocking, (I'm not) you'll enjoy the added stability, and the other components will enjoy a cooler case.
My northy block is plumbed in parallel, so the smaller block doesn't effect the flow through the cpu block. I purposely made the channels small so the cpu would get the lion's share of the waterflow, as it has the largest ammount of wattage to dissipate.
Istari1
Istari1
Raleigh NC
Hmm..but in parralell arent you losing basically half your flow through the CPU Wb but splicing the main line in 2? Or am I missing something? (I prolly am since I am by no means a watercooling expert). Funny thing is I have an Abit KR7A with some Corsair XMS2400 and I cant get anything above 139 FSB stable. . . I wonder if it may be my NB...damn. Thanks for that link man.
Josh
Diggrr
That's why I made the center channel on my northbridge waterblock so small. It's only 1/8" deep and 3/8" wide. This flow restriction guarantees that most of the waterflow goes through the cpu's waterblock.
The small northbridge block will only allow about (guessing here) 1/4 of the water flow through compared to the cpu's waterblock.
