Well my sp-94 (92mm tornado 119cfm LOUD) finally came in and I got everything all hooked up. I finally added some round IDE cables and added some fans for max cooling. My rig now overclocks nicely at 2.96 (fsb 624) max load 38 D. a major drop from 52 D. I also lapped my cpu which was surprisingly easy. That artic silver does take a few days to cure but it has dropped a few degrees over the last few days while doing so. I think I hit a brick wall on my OC ability. I can't seem to break the 3.0 mark. Any higher on the FSB will cause the cpu to NOT post in boot up. My volts are at 1.60 without any volt mod on the board (see below). I was wondering if upping the volts might hold the fsb higher. With the fluctuating volts from my mobo (no load to load) how high can I push the cpu voltage, higher than say 1.65v I know I shouldn't break 1.7 does that apply to idle volts or just load? Right now I get a fluctuation up to 1.66 while idle, which I think is alot.
Should I turn off turbo in bios?
Also, I have my memory setting set to auto which locks the memory and cpu to 1:1 should I set it to 5:4 if I could reach 166 on the FSB then 1:1 would be true but unlikely. Just looking for suggestions to try.
Now frustration sets in………….
Thanks
Thanks
