Not enough power – symptoms and worse case scenario
eco_bach
Hi
Just a question that's been bothering me. If you are ever in a build situation where you don't have enough power
1) What are the symptoms?
and
2) What is the worse case scenario? ie can mobo, CPU or GPU be damaged?
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
It will power off abruptly, typically. It can cause instability if the voltage are right in the edge due to being driven too hard.
What set up do you have and psu?
E
eco_bach
dual titan XP, Asus X99a2 i7 6900k , EVGA 1000W, Predator 360 cooling
Vishera
Are you experiencing issues with your system that led you to believe you might not have sufficient power?
