Not entering bios, jsut loads straight to windows
DaMaGeLIVE
Hey guys, just recently, I have not been able to go into my bios. Even if I press delete or tab during post, it just loads straight into windows. I use a gigabyte z68-ud4-b3 mobo. Firmware of f5. I already tried to clear my cmos by removing the battery. After doing that an option just popped up to use the last good settings. The problem still persists. Any ideas?
As soon as you press the power button, repeatedly push the button to get in the BIOS. Either it requires you to hit it before/after a certain event or you are pressing it at the wrong time.
Yea I've been doing what you said. I've been in and out of bios like a hundred times before this. Think it could be a firmware issue?
Not likely. Are you using a USB keyboard? If so, try a USB to PS/2 converter or use a PS/2 keyboard.
"Legacy USB" is probably disabled.
