- Dec 7, 2003
Not so DIY outside corner brackets
The goal of this project is to externally join a corner where 3 square tube frame elements meet.
This sub project is a close relative to my recently posted DIY Inside Corner Bracket.
http://www.overclockers.com/forums/showthread.php?t=699004
The history of this project goes back several years to my Exoframe Project.
http://www.overclockers.com/forums/showthread.php?t=597792
Specifically to this page of the build log:
http://www.overclockers.com/forums/showpost.php?p=5760709&postcount=8
While my DIY plastic brackets have worked great, they are a pain to build, and maybe not as strong as I like (glued joint).
So thanks to
Matt at Mione’s Solidworks for the CAD work
and
Erik at Norcal Laser for the cutting.
So thanks to
and
