I asked this over at OCN but thought I would ask it here for help too. There seems to be about a 30% chance of my kit, Gskill F4-3600C16D-32GTZNC (on Asus and Gskill QVL for the X570 Tuf which I'm using), to halt at reboot. My Tuf has its DRAM LED light on and it just halts there until I hold down my power button. I never got to try any other bios below 1403 as the first thing I did when I got the board was flash 1403. Then 1404 when it came out and finally now 1405. All three bios versions have this issue.
The odd thing about it is that, so far, it has been exclusive to rebooting. Not shutdown and powering back on and not from a cold boot after pulling out the power cord. But just from rebooting. And when it happens, once I hold down my power button to shutdown, and boot it back up, it boots just fine like normal. No issues when gaming long sessions, did prime95 well when I did my initial benchmark stuff, etc. I've tried clearing cmos, reflashing my bios, manually setting FCLK to 1800 and SOC voltage to 1.1v (which is what Auto with DOCP enabled was defaulting to), etc.
I did see a guy on newegg for the X570 Tuf complain about something that sounds very similar to what I have been enduring (chance of halting at boot up with his 3200mhz kit since updating to 1404 after coming from 1203 that worked fine) so it lends me to believe its a Asus bios issue. The guy was hinting at it being a DOCP issue. I am running it with DOCP. So yesterday I decided to write down my timings that where being set with DOCP and manually set everything. But I ran into a two problems.
The first problem is the very last timing to set in the bios, tcke, was post to be set to 0 (as 0 was the value DOCP was setting on auto) but when I put in 0, it changes it to 1. So some how auto sets it to 0 but manually I can't. Ryzen Master also shows it as 0 as well when DOCP is enabled. The second problem was after setting all the timings, memory to 3600, FCLK to 1800, DRAM voltage to 1.35v's, and SoC voltage to 1.1v's, my computer can't post. It just halts 100% of the time on the DRAM led light. So I had to clear cmos to get back in. So either that very last timing is what's causing the manual setting to fail to post or DOCP is also enabling other stuff that I can't figure out what else. Even though everything else is on auto by default either with or without DOCP, I'm assuming DOCP changes what those auto settings default to.
I am using slots A2 and B2 as well and fast boot in windows is disabled.
So because of that it does have me a bit concerned that maybe those times where I fail to reboot are not due to an Asus bios bug, but maybe hardware? Since I still have a return window for both a refund and replacement I don't know if I should gamble it?
I've run for an hour and a half of Ramtest from Karhusoftware that I found on OCN and after 1575% coverage, no errors. After that I ran Memtest Pro 7.0 for a bit over an hour to reach a little over 100% coverage and no errors. Ran both yesterday.
What do you guys think? Anyone else with a similar problem? Do you think its just Asus bios bug or hardware?
