- Jan 26, 2025
So, I'm getting ready to upgrade, and I'm at a bit of a crossroads as far as what platform I wanna go with for my next system. Right now, I have a Ryzen 5 1600AF (the 12nm refresh of the 1600, that is somehow different from the 2600), 32GB of DDR4, a GTX 1660 Super, and a Gigabyte Aorus Pro WiFi B450 motherboard. Work, games, it's all been a bit lacking, especially since I bought a second monitor that's 1440p75Hz. I would just go with a 5700X3D and upgrade to 64GB of RAM, but my motherboard has been through some crap, and a few of the USB ports don't work anymore. So, I'd like to start from scratch. So, it boils down to four options.
Option the First, aka The Money Saver: Buy a used X570 board, buy a 5700X3D and upgrade to 64GB of RAM as initially planned. The 64GB of RAM will be a constant through all of the options.
Option the Second: Go with 7000 series Ryzen. Pros being that it'd likely be easier to find a used CPU, save some money.
Option the Third: Go with 9000 series Ryzen. Theoretically, any "quirks" with 7000 series should be ironed out in this generation, but it hasn't been out for as long, so probably slimmer pickings for used CPUs, and not as big of a used discount. Really would only go this route if I've decided for sure I'm going AM5, and the extra performance over 7000 series is worth it.
Option the Fourth: Switch to Intel. If I were to go Intel, I would absolutely be buying new, because of the issues with the CPUs spontaneously going the way of the Dodo, so this option isn't as attractive to me due to cost. But depending on performance in my workloads, I'd be willing to consider it.
My main reason for even considering a 5000 series CPU is I seem to remember 7000 series having a lot of issues with thermals, to the point people were doing direct die cooling again, and at the very least, lapping your CPU's IHS was extremely popular. And 9000 series/Intel is just a bit pricey for my tastes at the moment, but I could compromise on some things to make it work. I'm a video editor, audio technician, and I also stream, so I'd definitely want at least an 8 core CPU, so probably looking at the 7800X3D/9800X3D. Maybe even 7900. Other than that, I'm looking for high refresh rate gaming at 1080p, like 120FPS+, or 75 at 1440p. Would prefer to be able to crank the settings, but am willing to compromise some on quality.
I'm really leaning more towards a 5700X3D or 7800X3D/7900X, and a 4060Ti, I'm just wondering if anyone has anything to say about if the extra money is worth it for 7000 series?
