- Nov 15, 2005
- Camarillo, CA!
OK well i just had a pretty good scare with regards to my server thats on 24/7....
its a P4 2.8C northwood on a gigabyte board (undervolted cpu to 1.3v) with 1gb of ram... the case has a rear 92mm at 5v, the psu i put in a adda low speed 80mm fan that runs @ 5.5v normally, the front intake is an antec tricool 120mm, i feed it 5V and have the speed switch set to medium (it barly starts up) and the cpu fan is the stock hs using a 120 to 80mm converter with another antec tri cool... this time being fed 7v with the switch on medium.... needless tosay the case dose not have tons of flow to begin with.
About 17 days ago i turned it off and blew the dust out of it, i also decided to remove the cpu fan and reroute the fan wires... so i get it back together and turn it on with the side open to make sure all the fans are spinning... all are so i closed her up and havnt payed much attention to it for 17 days....
Then bout 30 min ago i decided hmm lets check temps see how they r doing... cpu read 48*C... and the motherboard reads 20-25*C low so i quickly got the skrewdriver and took the side pannel off and lo and behold... cpu fan and rear exaust were not spinning (rear 92 has a 4pin molex passthrough that goes to the cpu fan 4pin) i was like... WTF they r plugged in but turns out the plug came loose and had a bad connection... so i forceably put them back together and they r spinnin now...
gah i just cant believe id let my self not check temps, it says something for the cpu... chillin at probably right at its thermal spec of 75*C idiling (less than 10% cpu usage) for who knows how long..
im just glad everything is alright...
Moral to the story... check temps on ur servers that just sit in the corner! give them their needed attention.
BTW cpu temps are back down to their normal range of 24-28*C
