Notebook CPU upgrade advise needed!!!
frost19k
Hey guys!
I have an Intel Mobile C2D T5550 running on the PM965 Chipset (NB) in my laptop.
I was thinking of upgrading the CPU to a T7700. Here's a comparison link.
I am 95% sure this will work in my system, I just looking for confirmation.
Thanks
Frost.
bsn1989
Lancaster, WI
I am pretty sure that will work Frost. I have upgraded from a T7250 to a T7200 in my brothers Dell studio with the 965 chipset. It worked like a charm. You shouldn't have any issues. Just as long as the FSB is the same, you should be good. :)
CompuTamer
Member with Some Fancy Text Under His Name
Brandon Mississippi
If the chipset will take the Chip, it should work... i'd be sure to keep an eye on temps though.. make sure they don't climb too high.
NVM: Should'a checked the chart first lol.
Yeah, as long as that chipset will take that chip, than you shouldn't have any problems at all.
Might loose a bit of battery life though.
