Today and tomorrow, I have to have all my subs in by midnight tomorrow. I time out of the novice league at that point
Also using XP and one stick of ram can help.
What are you using for RAM now. Adding a second stick may not help especially if it is not an identical stick. Yes, you want a drive dedicated to benching otherwise you will screw up your daily OS.
Oh and I got a sub in for stage one. 20.64 fps, not my best but my system is not cooperating today. Still need to do stage 2,4,5 but I should have them done in time.
http://hwbot.org/submission/3282440
Found a new stooge Lochkey!!??
Hey M@rk!
Kick ***, you have a legacy to live up too!!!
Probably gonna need more voltage. Are you running any program that allows you to adjust voltage and multiplier in Windows. If so boot in at a lower speed, kill all unneeded processes and then crank the speed and voltage.
I didn't boot at this speed. Software OC is necessary when benching. Back to that core selection the last screen you showed should be the option to change core count. Usually advanced CPU options but i'm not that familiar with MSIboards
