- Apr 3, 2015
- Planet Earth
careful now, dont put me in another existential crisis...Johan said:...there is no right answer.
Couple questions:
1. Do I need to restart 3D Van each time I change the LOD?
2. Should I expect consistent results at the same LOD value?
3-is realtime priority important?
Cause I set it, say to 3. It runs, but washes out towards the end, but I get a 10+ bumb in FPS.
I run again, it runs clean, and I am back stuck at ~165.
Many of these times I was just changing the LOD and re-running test, without closing.
Also, after the test, back at the UI, the priority is set back to "Normal".
So do I need to reset it as well each time?
Thanks for these clarifications, as otherwise I am unsure if my adjustments are actually having any effects?
Keep a look out for an update to The Bianch proj log later...Lochekey said:...hopefully the trend will continue with that new AMD chip
Prost
