- Sep 17, 2001
- Orange County
Über~PhLuBB said:I tried to find a way I could get a laser pointer to bounce back and forth INSIDE the window in my computer. I succeeded with a series of mirrors, but because the Lexan is perfectly smooth and has no internal imperfections, the laser light just passes through without being refracted. I tried scuffing up a little bit, but it didnt work the way I wanted.
Oh well, it was a good idea, just poorly implimented. =P
Krusty said:
If you aim the laser at the lexan at a shallow enough angle, it should reflect nicely. I am unsure of the reflective properties of lexan though, so I couldn't tell you what angle to do it at.
That is pretty much what I thought of when I saw the laser there.
Hmm...perhaps several of those tiny lasers of diggrrs each mounted on a small dc motor to make it spin. With 10 or so of those moving around all over the components in sight of the window, you could have a little Disco club inside your computer
Ooh! That just gave me an idea! A couple of tiny disco ball type things on slowly moving DC motors with orange and red LEDs aimed at them just might give an interesting fire effect inside the case...
With a small resistor inline, you could power them off the 3.3V line from the PSU.Über~PhLuBB said:You could run any of 'em off a 1.5 or 3.1 volt source, depending on how many 1.6v batteries they run on.
Crazy Jayhawk said:With a small resistor inline, you could power them off the 3.3V line from the PSU.
Krusty said:
Or run several of em in serial off of the 12v line. You could run 8 1.5v lasers in serial like that.
Über~PhLuBB said:
Series.![]()
