Nvidia Error - Help
ricvonhelms
NY
Hi all,
While playing unreal II i get the following error;
The Nvidia system sentinel is reporting that the Nvidia powered graphics card is not recieving sufficient power.
Why am i getting this all of a sudden?? See my signature below for my system specs. Far Cry and Painkiller ran without a hitch. I did install the drivers from Omegacorner.com. They run great and increased my 3DMark2001 score to 16818 from 15210. Other than that, i added the new Jetcooler 7 CPU cooler. Whats going on? Any thoughts??
R
ricvonhelms
NY
Update - I noriced in Coolbits that the 2D clock sets itself down from 300MHZ to 251MHZ. What gives!!
copernicus
ok this might be a stupid question but here goes :) did you plug a molex from your power supply into your card? cause that's the message you get if you don't.
lament
yeah or at least check the connection to make sure it's plugged in properly.
