- Jul 4, 2012
Depends on your fan, or more importantly on your old fan. It produces X pulses per second based on each complete rotation. You could open up the old fan and see how many magnets it has. Each magnet is one pulse per rotation as far as I understand it. Four magnets == 4 pulses. #pulsesPerSecond * 60 / numMagnets == RPM. 3000 rpm / 60 seconds would equal 50 rotations times 4 pulses, which would give you a square wave frequency of 200htz for full fan speed. This all changes based on how many magnets your original fan had. If you have access to an oscilloscope you could just turn the old fan on 100% and read the frequency the tach puts out. A 555 could be used to generate your square wave. There are also super cheap square wave generators on eBay. This solution would trick it into thinking all was well, but I’m not sure it would still control the fan right. You would need a pll for that.
One other option though. The old fan. Wire it up to a separate power source, molex or something. Use a pwm splitter to send the pwm signal to BOTH fans. Cut the blades off the old fan. Feed the tach signal from your now bladeless old fan back to the gpu. Instant solution. The old fan will buzz along somost silent with no blades. Just mount it somewhere.
